跳转到主内容
《SnapCenter—解决方案指南》中的删除备份、克莱姆、主机、策略和资源组
67
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • SnapCenter 服务器( SC )
  • SnapCenter 插件
问题解答
对象类型 主题 解决方案
备份
操作
故障排除
  • Failed to delete backup as there are clone(s) created from this backup
  • Cannot delete mounted backup or Failed to delete backup as the backup is already mounted.
克隆
操作
故障排除
主机
操作
故障排除
  • Failed to find host (host.domain.com). Verify if the host is up and running and check the DNS and firewall settings
  • Host name.domain.local is not registered with SnapCenter or is not DNS resolvable. Please try with a fully qualified name
策略
操作
故障排除
  • This policy has Resource Group attached. Please detach the policy from Resource Group before removing the policy
  • This <policy_name> policy has backup attached. Please remove the backup first before removing the policy
  • This NetApp.DataProtection.BuildingBlocks.Contracts.SmPolicy policy has backup attached
资源组
操作
故障排除
  • Resource group backup(s) are mounted. Please unmount backup(s) before removing the resource group
  • Failed to delete Resource Group: Backup component not found with resource id
  • Backup Deletion Failed: Backup <snapshot name> has mounts, cannot be deleted, unmount and retry again
  • Failed to delete resource group. Did not find any of the datastores or virtual machines to backup: [Datastore:datastore-####]
  • Remove-SmResourceGroup : The remote name could not be resolved: '<Host_FQDN>'
追加信息
附加信息 _text
