跳转到主内容
升级SnapCenter和ONTAP后、删除克隆生命周期卷克隆失败
163
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • SnapCenter服务器(SC) 5.0P1
  • 适用于Microsoft SQL Server的SnapCenter插件(SCSQL) 5.0P1
  • ONTAP 9.14.1P6
问题描述
在将SnapCenter升级到5.0P1并将ONTAP升级到9.14.1P6后、克隆生命周期作业期间删除卷克隆失败、并显示以下错误:
<JobID>_SMC.log <Date_Time>:
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xxxx] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: Failed to delete volume "<Volume_Name>" in Vserver "<Vserver_Name>" because it has one or more clones.  Use the "volume clone show -parent-vserver <Vserver_Name> -parent-volume <Volume_Name>" command to list clones, and either delete or split the clones and retry the operation.  Use "volume clone split start -vserver <vserver name> -flexclone <clone name>" to split clones. Use "volume delete -vserver <vserver name> -volume <clone name>" to delete clones.
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xxxx] No retry condition match found or max retry reached. Throwing error The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: Failed to delete volume "<Volume_Name>" in Vserver "<Vserver_Name>" because it has one or more clones.  Use the "volume clone show -parent-vserver <Vserver_Name> -parent-volume <Volume_Name>" command to list clones, and either delete or split the clones and retry the operation.  Use "volume clone split start -vserver <vserver name> -flexclone <clone name>" to split clones. Use "volume delete -vserver <vserver name> -volume <clone name>" to delete clones.
DEBUG SMCore_<JobID> PID=[xxxx] TID=[xxxx] --PSHelper::RunCommand
ERROR SMCore_<JobID> PID=[xxxx] TID=[xxxx] Message   : Failed to run a command Remove-NcVol
SnapCenter UI:
Storage Resource Clone Delete > Failed to get the LUN mapping information.,  Failed to get the LUN mapping infotmation.,
New to NetApp?
