跳转到主内容
FAS8300 关闭,电池容量过低警告
19
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • FAS8300
  • ONTAP 9.15.1P6
  • BMC 13.11P
问题描述
  • 节点意外关闭
  • EMS事件报告:
Call home for BATTERY capacity low WARNING
  • 查找带有 event log show -severity * -event *battery*
  • system battery show 输出时没有结果:
    • Current 字段显示"0 mA"
    • RelativeCharge 字段显示下面的71%
    • ChargingCurrent 字段显示"1000 mA"
  • 尝试引导 ONTAP 时的控制平台消息:
"the NVMEM battery capacity is low (1 cycles)"
battery charge capacity: 100 mA*hr..
WARNING: The battery is unfit to retain data during a power
outage. This is likely because the battery is
discharged but could be due to other temporary conditions.
When the battery is ready, the boot process will
complete and services will be engaged.
To override this delay, press 'c' followed by 'Enter
  • 启动 ONTAP 时,控制台卡在:
Waiting for nvram battery chargeup
  • 在 5 分钟或更长时间的间隔内运行 system battery show 显示 Voltage 正在下降
  • 在更长时间的间隔内运行 system battery show 可能显示 RelativeCharge 正在下降
New to NetApp?
