跳转到主内容
FAS8700/FAS8300/AFF A400/AFF C400 报告(机箱温度过高)错误警告
100
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • ONTAP 9
  • AFF A400、AFF C400、ASA A400、ASA C400
  • FAS8300
  • FAS8700
问题
  • 两个节点中机箱温度的每小时错误消息。示例
[node_name-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (LED1 Temp) is not readable.
[node_name-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (LED2 Temp) is not readable.
[node_name-01: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
[node_name-02: env_mgr: monitor.temp.unreadable:error]: The controller temperature (LED1 Temp) is not readable.
[node_name-02: env_mgr: monitor.temp.unreadable:error]: The controller temperature (LED2 Temp) is not readable.
[node_name-02: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
  • AutoSupport 生成于:
HA Group Notification (CHASSIS OVER TEMPERATURE) ERROR
  • LED1 或 LED2 温度传感器故障。示例:
::> system node run -node node_name-01 -command environment chassis list-sensors
Sensor Name   State       Current   Critical    Warning    Warning   Critical
                 Reading    Low      Low      High     High
LED1 Temp   failed       -- C    0 C      3 C     43 C    46 C
::> system node run -node node_name-01 -command environment status chassis
LED1 Temp                not_available    -- C         0 C         3 C        43 C        46 C
LED2 Temp                not_available    -- C         0 C         3 C        43 C        46 C
  • "No reading" 输出 BMC 调试日志中的 LED 传感器。示例:
LED1_Temp        | 16h     | ns     | 12.1  | No Reading
LED2_Temp        | 17h     | ns     | 12.1  | No Reading
LED1_Temp        | na         | degrees C  | na    | na        | 0.000     | 3.000     | 43.000    | 46.000    | na
LED2_Temp        | na         | degrees C  | na    | na        | 0.000     | 3.000     | 43.000    | 46.000    | na
  • 在某些情况下,节点也可能会 Panic 并显示以下消息:
[node_name-02: env_mgr: monitor.shutdown.chassisUnderTemp:error]: Chassis temperature is too cold: Ambient temperature is critical low. System will be shutdown immediately
[node_name-02: monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too low..
[node_name-02: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Temperature critical)
[node_name-02: mgwd: mgwd.notify.halt.result:info]: MGWD able to notify CLAM on its HA partner node that this node is undergoing a planned shutdown (reason: E). Error: -
New to NetApp?
