跳转到主内容
E 系列驱动器更换后路径冗余丢失
334
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
适用于
NetApp E-Series
问题
  • 更换驱动器后,E系列在恢复专家中报告 NO_REDUNDANCY_DRIVE-Recovery Failure Type Code: 32 和在存储阵列配置文件中报告  Loss of redundancy
  • 在 存储阵列配置文件
SHELF, DRAWER, BAY STATUS CAPACITY MEDIA TYPE INTERFACE TYPE CURRENT DATA RATE PRODUCT ID
99、1、0 冗余丢失 1,490.415 GB 固态磁盘 SAS 12 Gbps KPM5WVUG1T60
  • Recovery Guru 报告冗余丢失
Failure Entry 1: NO_REDUNDANCY_DRIVE-Recovery Failure Type Code: 32 Storage array: StorageGRID-node01 Component reporting problem: Drive in bay 0 Status: Optimal Location: Controller/Drive shelf 99, Drawer 1
New to NetApp?
