vifmgr.cluscheck.crcerrors:在多个端口和节点中发出警报
适用场景
- 所有FAS / AFF
- 数据网络端口
问题描述
- 多个节点的不同端口出现多个CRC错误。示例:
[node_name-01: vifmgr: vifmgr.cluscheck.crcerrors:alert]: Port e8e on node node_name-01 is reporting a high number of observed hardware errors, possibly CRC errors.
[node_name-02: vifmgr: vifmgr.cluscheck.crcerrors:alert]: Port e10e on node node_name-02 is reporting a high number of observed hardware errors, possibly CRC errors.
[node_name-01: vifmgr: vifmgr.cluscheck.crcerrors:alert]: Port e1a on node node_name-01 is reporting a high number of observed hardware errors, possibly CRC errors.
[node_name-02: vifmgr: vifmgr.cluscheck.crcerrors:alert]: Port e1a on node node_name-02 is reporting a high number of observed hardware errors, possibly CRC errors.
[node_name-02: vifmgr: vifmgr.cluscheck.crcerrors:alert]: Port e8e on node node_name-02 is reporting a high number of observed hardware errors, possibly CRC errors.
- 这些端口的CRC错误增加。示例:
Node node_name-01:
-- interface e1a (1 day, 9 hours, 27 minutes, 0 seconds) --
RECEIVE
Total frames: 142k | Frames/second: 1 | Total bytes: 23646k
Bytes/second: 196 | Total errors: 7 | Errors/minute: 0
Non-primary u/c: 0 | CRC errors: 7 | Runt frames: 0
-- interface e8e (1 day, 9 hours, 27 minutes, 9 seconds) --
RECEIVE
Total frames: 133k | Frames/second: 1 | Total bytes: 19800k
Bytes/second: 164 | Total errors: 4 | Errors/minute: 0
Non-primary u/c: 0 | CRC errors: 4 | Runt frames: 0
Node node_name-02
-- interface e1a (557 days, 2 hours, 57 minutes, 54 seconds) --
RECEIVE
Total frames: 64746k | Frames/second: 1 | Total bytes: 10702m
Bytes/second: 222 | Total errors: 91 | Errors/minute: 0
Non-primary u/c: 0 | CRC errors: 91 | Runt frames: 0
-- interface e8e (25 days, 19 hours, 0 minutes, 1 second) --
RECEIVE
Total frames: 5835k | Frames/second: 3 | Total bytes: 1150m
Bytes/second: 516 | Total errors: 44 | Errors/minute: 0
Non-primary u/c: 0 | CRC errors: 44 | Runt frames: 0
-- interface e10e (15 days, 18 hours, 10 minutes, 56 seconds) --
RECEIVE
Total frames: 1451k | Frames/second: 1 | Total bytes: 207m
Bytes/second: 152 | Total errors: 50 | Errors/minute: 0
Non-primary u/c: 0 | CRC errors: 50 | Runt frames: 0
- 前端数据交换机中先前端口连接到的接口会报告输出错误、而不是输入错误。示例:
data_switch-1# show interface Ethernet1/48
Ethernet1/48 is up
admin state is up, Dedicated Interface
RX
7724 unicast packets 59832 multicast packets 0 broadcast packets
67556 input packets 8562626 bytes
0 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 Stomped CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 input buffer drop 0 input total drop
0 Rx pause
TX
87462 unicast packets 471164 multicast packets 1207793 broadcast packets
1766442 output packets 257533918 bytes
18 jumbo packets
23 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 output buffer drops 0 output total drops
0 Tx pause
data_switch-2# show interface Ethernet1/31
Ethernet1/31 is up
RX
273949 unicast packets 2121655 multicast packets 298 broadcast packets
2395902 input packets 292674535 bytes
682 jumbo packets 0 storm suppression bytes
0 Rx pause
TX
602784 unicast packets 10301779 multicast packets 29858428 broadcast packets
40763146 output packets 5398888609 bytes
111 jumbo packets
155 output error 0 collision 0 deferred 0 late collision
0 Tx paus
