跳转到主内容
由于 NSM100 FW 161 及更早版本在 NS224 磁盘架上出现纽扣电池错误
39
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
适用于
  • NS224 盘架
  • NSM 固件 161 及早期版本
问题
  • NS224 机架模块 NSM100 错误或警报:
Wed Feb 03 18:50:32 +0100 [node_name: dsa_worker4: ses.status.battery.error:error]: NS224NSM100 (S/N SHFHU0123456789) shelf 0 on channel 0x battery failure error for Coin Battery 1: not installed or hardware failure. This element is on the rear of the shelf, in bottom module (B).
Wed Feb 03 18:50:42 +0100 [node_name: dsa_worker3: ses.status.battery.threshErr:alert]: NS224NSM100 (S/N SHFHU0123456789) shelf 0 on channel 0x battery failure error for Coin Battery 1: critical status. This element is on the rear of the shelf, in top module (A).
  • 存储故障输出
::> system node run -node <node_name> -command storage show fault -v
Coin Cell Battery:
Element Status                      Status Bytes  Status Descriptions
    1 [NSM100 A]    : CRITICAL         02,02,0A,46   LCR
    2 [NSM100 B]    : OK                01,00,0B,34
  • 硬币电池的环境错误:
Coin Battery installed element list: 1, 2; with error: 1
Coin Battery information by element:
   [1] Voltage: 2.630
   [2] Voltage: 2.868
  • 错误可能是间歇性的
New to NetApp?
