跳转到主内容
电池不存在、nvdimm.nvmem.destage.failure:ALERT
117
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
适用场景
  • AFF系统
  • ASA系统
  • FAS系统
问题描述
  • 节点在启动时报告以下警告消息:
nvdimm.nvmem.destage.failure:ALERT]:NVMEM subsystem fail to start or complete destage process, please check battery or NVDIMM.. Copyright (C) 1992-2024 NetApp.All rights reserved. ******************************** [240515064243][13225:13225:bmc][WARN][easybat_api.c:__easybat_is_present:533] battery is absent (I2C) Battery Revision : Fail to get version b02 | 11/16/2023 | 18:22:39 | Battery Bat_Dstg_Cycles | Lower Non-critical going low | Asserted | Reading 5 < Threshold 5 cycles b03 | 11/24/2023 | 22:28:49 | Battery Bat_Dstg_Cycles | Lower Critical going low | Asserted | Reading 2 < Threshold 2 cycles b04 | 12/05/2023 | 14:15:10 | Voltage Bat_Volt | Lower Non-critical going low | Asserted | Reading 5.60 < Threshold 5.60 Volts b05 | 12/05/2023 | 16:39:40 | Voltage Bat_Volt | Lower Critical going low | Asserted | Reading 5.50 < Threshold 5.50 [240515054739][1382:1382:btlearningapp][WARN][easybat_api.c:__easybat_is_present:533]battery is absent (I2C) [240515054740][168:354:easyinitd][WARN][easyinitd_wdt.c:monitor_service:100]sshd is not started yet, might still generate keys [240515054754][1915:1915:batapp][WARN][easybat_api.c:__easybat_is_present:533]battery is absent (I2
  • 从BMC运行  system battery show 报告
BMC FAS> system battery show [240516052103][13945:13945:batapp][WARN][easybat_api.c:__easybat_is_present:533]battery is absent (I2C) Battery doesn't present, bye
New to NetApp?
