AFF A250、A400、FAS 9300和FAS 4700报告电池(容量不足)警报
适用场景
- AFF A250/FAS500f
- AFF A400 / FAS8300 / FAS8700
- ONTAP版本:
- 9.7P19或更低版本
- 9.8P12或更低版本
- 9.9.1P8或更低版本
- 9.10.1P2或更低版本
Call home for BATTERY (capacity low) WARNING
问题描述
- 事件
::>event log show -severity * -event *battery*
1/1/2022 00:00:00 node-name ALERT callhome.battery.low: Call home for BATTERY_LOW.
1/1/2022 00:00:00 node-name EMERGENCY monitor.nvramLowBattery: NVRAM battery is dangerously low.
1/1/2022 00:00:00 node-name ALERT callhome.battery.warning: Call home for BATTERY (capacity low) WARNING.
- 电池电量不足的BMC事件
BMC>events search Battery
51d | 03/11/2022 | 14:03:02 | Battery #0x4f | State Asserted
51e | 03/11/2022 | 15:47:58 | Battery #0x49 | Lower Non-critical going low
51f | 03/11/2022 | 15:57:35 | Battery #0x49 | Lower Non-critical going low
520 | 03/11/2022 | 18:27:42 | Battery #0x49 | Lower Non-critical going low
system sensors show
报告Bat_Dstg_Cycles
低于lnc
阈值
BMC>system sensors show
=================== sensor ==========================
Sensor name | reading | unit | status| lnr | lcr | lnc | unc | ucr | unr
Bat_Temp | 34.500 | degrees C | ok | 0.000 | 0.000 | 5.000 | 60.000 | 75.000 | 127.500
Bat_Volt | 8.100 | Volts | ok | 0.000 | 5.500 | 5.600 | 8.500 | 8.600 | 12.750
Bat_Curr | 0.000 | Amps | ok | na | na | na | 1.200 | 1.520 | 2.540
Bat_Rem_Cap | 9.840 | Watts * hour | ok | na | na | na | na | na | na
Bat_Full_Cap | 10.800 | Watts * hour | ok | na | na | na | na | na | na
Bat_Charge_Curr | 0.000 | Amps | ok | na | na | na | 2.200 | 2.300 | 5.100
Bat_Charge_Volt | 8.200 | Volts | ok | na | na | na | 8.900 | 9.000 | 12.750
Bat_Design_Cap | 18.400 | Watts * hour | ok | na | na | na | na | na | na
Bat_Initial_Fcc | 20.400 | Watts * hour | ok | na | na | na | na | na | na
Bat_Dstg_Cycles | 4.000 | cycles | nc | na | 2.000 | 5.000 | na | na | na
Bat_Cycle_Cnt | 0.000 | cycles | ok | na | na | na | na | na | na
Bat_Power_Fault | 0x0 | discrete | 0x0180| na | na | na | na | na | na
Bat_Dsg_FET_Flt | 0x0 | discrete | 0x0280| na | na | na | na | na | na
Bat_Chg_FET_Flt | 0x0 | discrete | 0x0280| na | na | na | na | na | na
Bat_Pack_Invalid | 0x0 | discrete | 0x0180| na | na | na | na | na | na
Bat_Lrn_Active | 0x0 | discrete | 0x0280| na | na | na | na | na | na
- 电池记忆周期在SP最新IPMI中处于活动状态
LrnCyclProgress : 0x01
Learn Load Enabled : TRUE
LrnCycleStartDate : 22-03-11-14:03
LrnCycleStartFCC : 0x054b
LrnCycleEndFCC : 0x0000
LrnCycleEndDate : ??-??-??-??:??
