跳转到主内容
AFF-A250一个节点报告配对PSU上的机箱电源降级
75
Visibility:
Votes:
0
Category:
fas-systems<a>2009年278627</a>
Specialty:
hw
Last Updated:
适用场景
  • AFF-A250
  • FAS500f
问题描述
  • AFF-A250一个节点在 CHASSIS POWER SUPPLY DEGRADED 配对PSU上报告警报。例如、控制器B报告PSU1已降级、或者控制器A报告PSU2已降级。
  • 使用问题描述 的节点中的PSU传感器不可读、但配对节点无法读取。示例:
[?] Mon Aug 22 20:08:07 +0800 [Node-02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Inlet is Unreadable
[?] Mon Aug 22 20:08:07 +0800 [Node-02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Hot is Unreadable
[?] Mon Aug 22 20:08:07 +0800 [Node-02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 FB Hot is Unreadable
[?] Mon Aug 22 20:08:07 +0800 [Node-02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Fan is Unreadable
[?] Mon Aug 22 20:08:07 +0800 [Node-02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 In Fault is Unreadable
[?] Mon Aug 22 20:08:07 +0800 [Node-02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Warning is Unreadable
[?] Mon Aug 22 20:08:07 +0800 [Node-02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Out Fault is Unreadable
[?] Mon Aug 22 20:08:09 +0800 [Node-02: power_low_monitor: monitor.chassisPower.degraded:alert]: Chassis power is degraded: Power Supply Status Critical: PSU1.
[?] Mon Aug 22 20:08:09 +0800 [Node-02: power_low_monitor: callhome.chassis.power:error]: Call home for CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU1.
New to NetApp?
