跳转到主内容
SwitchFanNotOperational_Alert—AutoSupport 消息
2
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
适用场景
  • ONTAP 9
  • Cisco Nexus集群交换机
  • 对于运行状况监控器进程cshm、请致电home:SwitchFanNotOperational_Alert
事件摘要
如果未检测到风扇电源、并且风扇状态显示为非运行、则会发送SwitchFanNotOperational_Alert。
验证
主叫事件
HA Group Notification from Node Name (Health Monitor process cshm: SwitchFanNotOperational_Alert[Switch Name(Switch Serial Number)/Fan Module-3]) ALERT
EMS日志
event log show -severity * -message-name callhome*
[Node Name: mgwd: callhome.hm.alert.major:alert]: Call home for Health Monitor process cshm: SwitchFanNotOperational_Alert[Switch Name(Switch Serial Number)/Fan Module-3].
命令行
system health alert show -node <node name> -monitor cluster-switch -alert-id SwitchFanNotOperational_Alert
            Node: Node01
          Monitor: cluster-switch
       Class of Alert: SwitchFanNotOperational_Alert
     Severity of Alert: Major
       Probable Cause: Out_of_service
Probable Cause Description: "Fan Module-3" on switch "Switch Name(Switch Name)" is not functioning properly.
      Possible Effect: Cooling of switch "Switch Name(Serial Number)" might be degraded.
     Corrective Actions: 1) Use the switch CLI to verify that the fan is functioning at the expected speed.                      2) Replace the fan, if it is not operational.
交换机日志输出:
switch_name# show environment fan detail
Fan:
Fan        Model         Hw    Direction     Status
Fan1(sys_fan1)  NXA-FAN-30CFM-F    --    back-to-front  Failure
Fan2(sys_fan2)  NXA-FAN-30CFM-F    --    back-to-front   Ok
Fan:
Fan Name      Fan Num   Fan Direction   Speed(%)  Speed(RPM)
Fan1(sys_fan1)    fan1   back-to-front   0     0
Fan1(sys_fan1)    fan2   back-to-front   100     11563
解决方法
如需进一步帮助、请联系Cisco技术支持中心。解决方案 可能需要更换部件。
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
