跳转到主内容
由于机箱风扇故障、报告了"有故障的FanXFruFault"警报
14
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw<a>2008704817</a><a>进行翻译</a>
Last Updated:
适用场景
  • ONTAP 9
  • AFF A400
  • FAS9000
  • FAS8700
  • FAS8300
问题描述
  • 事件日志中的风扇模块报告了以下错误:
[Node1: env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: Fan2_2 (failed)
[Node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Fan2_2
[Node1: monitor: monitor.globalStatus.critical:EMERGENCY]: One fan has failed: SysFan2 F2.
[Node1: cphmd: hm.alert.raised:alert]: Alert Id = CriticalFan2FruFaultAlert , Alerting Resource = 021XXXXXXXX882 raised by monitor chassis
[Node1: mgwd: callhome.hm.alert.critical:alert]: Call home for Health Monitor process cphm: CriticalFan2FruFaultAlert[021XXXXXXXX882].
  • SP-LATEST-IPMI AutoSupport部分显示受影响风扇的严重状态:
hsamcmd --fault-show-all
tag  origin  fld            fault reason                   count  time
1   0x5   /chassis-1/fan-2    ipmi Fan2_Speed2 lower non-critical        1    Tue May  9 19:20:38 2023
2   0x5   /chassis-1/fan-2    ipmi Fan2_Speed2 lower critical         1    Tue May  9 19:20:38 2023
FAN2:
Fan2_Status    | 0x0     | discrete   | Ready    | na     | na     | na     | na
Fan2_Current    | 6.150    | Amps     | ok      | 0.000    | 0.500    | 10.000   | 12.000
Fan2_Speed1    | 8300.000   | RPM     | ok      | 1000.000  | 1250.000  | 9750.000  | 10000.000
Fan2_Speed2   | 0.000    | RPM     | cr      | 1000.000  | 1250.000  | 9750.000  | 10000.000
Fan2_Speed3    | 8300.000   | RPM     | ok      | 1000.000  | 1250.000  | 9750.000  | 10000.000
Fan2_Speed4    | 8250.000   | RPM     | ok      | 1000.000  | 1250.000  | 9750.000  | 10000.000
New to NetApp?
