呼叫机箱风扇 FRU 故障传感器故障无读数
适用于
- ONTAP 9
- 机箱风扇
问题
- 在事件日志中报告以下错误:
[Node-02: env_mgr: monitor.chassisFan.stop:debug]: Chassis fan contains at least one stopped fan: Fan1 (0 RPM)
[Node-02: env_mgr: callhome.c.fan.fru.fault:debug]: Call home for CHASSIS FAN FRU FAILED: Fan1
或
[Node-04: env_mgr: monitor.chassisFan.stop:debug]: Chassis fan contains at least one stopped fan: Sysfan4_F2_Speed (failed)
[Node-04: env_mgr: callhome.c.fan.fru.fault:debug]: Call home for CHASSIS FAN FRU FAILED: Sysfan4_F2_Speed
- 一个或两个风扇的传感器状态在 SP 传感器部分为
"BAD":
Fan2 State discrete normal normal GOOD
Fan1 State discrete fault normal BADSensor name | reading | unit | status| lnr | lcr | lnc | unc | ucr | unr
Sysfan4_F1_Speed | 9204.000 | RPM | ok | 0.000 | 936.000 | 2964.000 | 33072.000 | 34008.000 | 34944.000
Sysfan4_F2_Speed | 0.000 | RPM | nr | 0.000 | 936.000 | 2964.000 | 33072.000 | 34008.000 | 34944.000 或
Fan1_1 | 70h | ok | 29.1 | 9100 RPM
Fan2_1 | 71h | ok | 29.2 | 9000 RPM
Fan3_1 | 72h | ok | 29.3 | 9100 RPM
Fan4_1 | 73h | ok | 29.4 | 9100 RPM
Fan1_2 | 74h | ns | 29.1 | No Reading
Fan2_2 | 75h | ok | 29.2 | 9200 RPM
Fan3_2 | 76h | ok | 29.3 | 9000 RPM
Fan4_2 | 77h | ok | 29.4 | 9100 RPM-
SP-LATEST-RUNTIME报告节点注意 LED 亮起:
1 LED_SYSTEM_ATTEN_01 is on50 LED_FAN_ATTEN_02 is on
