跳转到主内容
Bat 3.0伏严重不足
119
Visibility:
Votes:
0
Category:
fas-systems<a>2009257194</a>
Specialty:
hw
Last Updated:
适用场景
  • FAS2554
  • FAS2520
  • ONTAP 9
问题描述
  • EMS报告 Bat 3.0V is critical low
[?] Tue Aug 02 00:47:36 CST [Node A: env_mgr: monitor.chassisPower.degraded:warning]: Chassis power is degraded: Bat 3.0V is critical low (1387 mV). Please replace the CMOS coin cell battery.
  • SP-LATEST-IPMI  报告 Bat_3.0V 失败。
 Bat_1.5V | 1.504 | Volts | ok | 1.280 | 1.348 | 1.649 | 1.727 Bat_3.0V | 1.430 | Volts | cr | 2.545 | 2.703 | 3.504 | 3.575 Bat_8.0V | 7.900 | Volts | ok | 6.000 | 6.600 | 8.600 | 8.700 Bat_Curr | 0.000 | Amps | ok | na | na | 0.800 | 0.900 Bat_Capacity | 2.304 | Amps*hour | ok | na | na | na | na Bat_Run_Time | 148.000 | hour | ok | 76.000 | 78.000 | na | na Bat_Temp | 27.000 | degrees C | ok | 0.000 | 10.000 | 55.000 | 64.000
New to NetApp?
