跳转到主内容
NS224 磁盘架上的纽扣电池错误
166
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • NS224 存储盘架
  • NSM100 盘架模块,带固件 0162 及更高版本
  • NSM100B 盘架模块
问题
  • NS224 磁盘架模块 NSM100 (NS224NSM100) 警报:
Thu Feb 15 22:20:02 -0600 [node1: ses.status.battery.error:error]: NS224NSM100 (S/N SHJXXXXXXXXXX) shelf 4 on channel 0x battery failure error for Coin Battery 1: not installed or hardware failure. This element is on the rear of the shelf, in top module (A).
  • 货架上的注意 LED 亮起。
  • 存储故障输出:
Coin Cell Battery: Element Status Status Bytes Status Descriptions 1 [NSM100 A] : CRITICAL 02,02,01,AE LCR 2 [NSM100 B] : OK 01,00,0B,B3
  • 硬币电池的环境错误:
Coin Battery installed element list: 1, 2; with error: 1 Coin Battery information by element: [1] Voltage: 0.430 [2] Voltage: 2.995
New to NetApp?
