跳转到主内容
E系列永久缓存备份设备出现故障 - AutoSupport 消息
233
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
适用于
NetApp E 系列
事件摘要
  • Persistent cache backup device has failed 在 SANtricity 的事件日志中报告
  • CACHE BACKUP DEVICE - Failed 错误消息在 Recovery Guru 中显示。
    • 此外,可能会记录 CACHE_BACKUP_DEVICE_INSUFFICIENT_CAPACITY 恢复专家失败条目。
E-Series Persistent cache backup device has failed
  • 用于在断电或突然断电时刷新缓存的 mSATA 驱动器出现故障。
    • 根据系统配置的不同,可能会显示警报,指示缓存已禁用或暂停。如果缓存备份设备出现故障,这是可以预料的。
      • Failure Entry 2: WB_CACHING_FORCIBLY_DISABLED-Recovery Failure Type Code: 378
验证
  • Storage Array Profile 日志指示缓存备份设备出现故障。
  • 示例:
Cache Backup Device
       Status:           Failed
       Type:            SATA flash drive
       Capacity:          8,192 MB
       Wear Life Used:       0%
       Endurance Remaining:     100%
       P/E Cycles:         15
       Product ID:         ATP SATA III mSA
       Part number:         Not Available
       Serial number:        210703540063
       Revision level:       R082
       Manufacturer:        ATP
       Date of manufacture:     Not available
解决方法
The solution might require a part replacement. Please contact NetApp Technical Support or log into the NetApp Support Site to create a case. Reference this article for further assistance.
New to NetApp?
