跳转到主内容
无法接管: ONTAP Select 中本地节点缺少配对磁盘
167
Visibility:
Votes:
0
Category:
ontap-select
Specialty:
core
Last Updated:
适用场景
ONTAP Select
问题描述
  • 由于VMware基础架构中影响ONTAP Select节点上NIC的网络问题
  • 节点报告无法进行故障转移
Node: node01
Node Name as Returned by Storage Failover Component: node01
Partner Name: node02
Node NVRAM ID: XXXXXXXXXX
Partner NVRAM ID: XXXXXXXXXX
Takeover Enabled: true
HA Mode: ha
Takeover Possible: false
Reason Takeover not Possible: Local node missing partner disks
Reason Takeover not Possible (Enum value): disk_inventory_mismatch_local
Interconnect Up: true
Interconnect Links: RDMA Interconnect is up (Link up)
Interconnect Type: MVIA-RDMA
State Description: Connected to node02, Takeover is not possible: Local node missing partner disks
Partner State: Up
  • EMS日志中的节点上存在与网络中断相对应的错误
8/16/2023 20:37:50  node02 ERROR         callhome.sfo.miscount: Call home for HA GROUP ERROR: DISK/SHELF COUNT MISMATCH
8/16/2023 20:37:50  node02 ERROR         cf.disk.inventory.mismatch: Status of the disk 0f.21 (32343637:65386464:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000) has recently changed or the node (node02) is missing the disk.
8/16/2023 20:37:50  node02 ERROR         cf.disk.inventory.mismatch: Status of the disk 0f.22 (33376335:37306161:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000) has recently changed or the node (node02) is missing the disk.
  • 拥有磁盘的配对节点会报告磁盘运行状况良好
New to NetApp?
