跳转到主内容
在适用于集群的 ONTAP Select Deploy 中,网络连接检查程序失败 加入
9
Visibility:
Votes:
0
Category:
ontap-select
Specialty:
cloud
Last Updated:
适用于
ONTAP Select Deploy (部署)
ONTAP Select ( OTS )
分布式资源计划程序( DRS )
问题
由于出现集群加入错误消息,在 Deploy 中运行连接检查程序失败。
示例:
ONTAPClusterCreateJoinOperationFailed: ONTAP cluster create failed during cluster join operation on cluster "mySelectCluster". Reason: Failed to start cluster join on node: 169.254.10.200: Setup failed between nodes node1 and node2 with :Could not retrieve partner SFO information: entry doesn't exist. Resolve the issue, then try the command again.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
