跳转到主内容
删除证书后、使用HTTPS的ONTAP AutoSupport验证失败
27
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用场景
  • ONTAP 9.7 及更高版本
  • AutoSupport
  • 传输HTTPS
问题描述
  • 从信任存储库中删除某些证书后、AutoSupport不再成功:
cluster1::*>system node autosupport check show-details -node * -check-type https-post-destination
Node: cluster1-01
Category: https
      Component: https-post-destination
       Status: failed
       Detail: HTTPS POST connectivity check failed for destination:
https://support.netapp.com/asupprod/post/1.0/postAsup.
           Error: Peer certificate can not be authenticated with
           given Certificate Authority certificates.
  Corrective Action: Certificate issue. Please make sure you have the correct
           Root Certificate installed
  • 验证是否缺少以下证书
cluster1::>security certificate show-truststore -common-name AAACertificateServices
There are no entries matching your query.
cluster1::> security certificate show -common-name AAACertificateServices
发生原因
  • 缺少server-CA证书、 ONTAP使用此证书 向 HTTPS支持URL support.netapp.com/asupprod/post/1.0/postAsup进行身份验证
  • 此证书的公用名称为 AAACerticateServices
  • 已通过以下两种方式之一删除此证书:
  • 错误 ID 1221636会跟踪此问题描述
解决方案
要解决此问题描述、请选择以下选项之一:
重新加载信任存储库
cluster1::*>security certificate truststore load
手动添加用于AutoSupport的单个证书
  • 这将添加回  AAACerticateServices根证书
  • 以下是 截至本文发布时的当前AAACerticateServices证书;但是、最好使用信任存储库、因为它可以确保加载当前证书
  • 使用 security certificATE install 命令:
cluster1::>security certificate install -type server-ca
Please enter Certificate: Press <Enter> when done
-----BEGIN CERTIFICATE-----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==
-----END CERTIFICATE-----
You should keep a copy of the CA-signed digital certificate for future reference.
The installed certificate's CA and serial number for reference:
CA: AAA Certificate Services
serial: 01
The certificate's generated name for reference: AAACertificateServices
追加信息
临时临时解决策
  • 可以通过 禁用证书验证来解决此问题
  • 这将配置集群中的所有控制器、使其不会验证从support.netapp.com收到的服务器证书
  • 这是一个临时修复程序、用于恢复传输AutoSupport日志、直到完全解析问题描述为止
  • 将存储控制器配置为在验证过程中跳过服务器证书
cluster1::>system node autosupport modify -node <node> -transport https -support enable -validate-digital-certificate false
New to NetApp?
