跳转到主内容
在ESXi主机端持续收到路径冗余降级警报
316
Visibility:
Votes:
0
Category:
fas-systems<a>2009538340</a><a>用于翻译</a>
Specialty:
san
Last Updated:
适用场景
  • ONTAP 9
  • FC LUN
  • ESXi 主机
  • Brocade 交换机上的端口
问题描述
  • ESXi主机在VMware端持续收到以下警报。
Alarm alarm.StorageConnectivityAlarm on Host hostabc.xxx.com
because Path redundancy to storage device naa.600a098xxxxxx46c3f515xxxxxxxx degraded. Path vmhba2:C0:xx:xx0 is down. Affected datastores: xxx-NetApp-xyz..
Alarm name  alarm.StorageConnectivityAlarm
Description alarm.StorageConnectivityAlarm
Target    Host hostabc.xxx.com
Triggered time   04/10/2023 10:40:57 AM
  • FC LUN会从NetApp存储映射到这些主机。
  • 主机端不会因这些警报而发生中断。
  • 在主机端生成警报的频率非常高、大约需要3小时左右。
  • 在问题描述时间戳期间、存储端的LUN处于联机状态并已映射、EMS日志中未发现任何错误。
  • FC端口均已启动,Rx、Tx值处于 最佳范围。
  • Brocade交换机日志分析表明、交换机与NetApp存储之间存在端口的问题描述。
  • Switchshow 报告端口联机
/fabos/bin/switchshow :
Index Port Address  Media Speed   State       Proto
   9   9   020900   id    N8   Online      FC  F-Port  1 N Port + 1 NPIV public
  • Porterrshow 表示端口报告了多个介质错误。
/fabos/cliexec/porterrshow :
      frames    enc   crc   crc   too   too   bad   enc   disc   link   loss   loss   frjt   fbsy  c3timeout   pcs   uncor
    tx    rx    in   err   g_eof  shrt   long   eof    out   c3   fail   sync   sig          tx   rx    err   err
  9:   3.4g   1.5g  39.4k  30.9m 30.5m   0    11.3k 454.4k  2.1m  79.2k 206    0    2.4k   0    0    0    0   264.1m   0
  • 根据 sfpshow 观察结果、Rx值不在最佳范围内、而Tx值在最佳范围内。
Port  9:
Identifier:  3   SFP
Connector:   7   LC
Transceiver: 7004404000000000 4,8,16_Gbps M5 sw Short_dist
Vendor Name: HP-F    BROCADE
Vendor OUI:  00:05:1e
Vendor PN:   QK724A
RX Power:   -12.1   dBm (61.0 uW)
TX Power:   -3.2   dBm (483.8 uW)
  • Portstatsshow 表示端口遇到多个问题。
portstatsshow 9
fec_cor_detected     0           Count of blocks that were corrected by FEC
fec_uncor_detected    0           Count of blocks that were left uncorrected by FEC
er_enc_in         39648         Encoding errors inside of frames
er_crc          30968151       Frames with CRC errors
er_trunc         0           Frames shorter than minimum
er_toolong        11379         Frames longer than maximum
er_bad_eof        454430        Frames with bad end-of-frame
er_enc_out        2172705        Encoding error outside of frames
er_bad_os        3801509        Invalid ordered set
er_pcs_blk        264192520       PCS block errors
er_rx_c3_timeout     0           Class 3 receive frames discarded due to timeout
er_tx_c3_timeout     0           Class 3 transmit frames discarded due to timeout
er_unroutable       20153         Frames that are unroutable
er_unreachable      0           Frames with unreachable destination
er_other_discard     79253         Other discards
er_type1_miss       0           frames with FTB type 1 miss
er_type2_miss       0           frames with FTB type 2 miss
er_type6_miss       0           frames with FTB type 6 miss
er_zone_miss       71          frames with hard zoning miss
er_lun_zone_miss     0           frames with LUN zoning miss
er_crc_good_eof      30502349       Crc error with good eof
er_inv_arb        0           Invalid ARB
er_single_credit_loss   0           Single vcrdy/frame loss on link
er_multi_credit_loss   0           Multiple vcrdy/frame loss on link
other_credit_loss     0           Link timeout/complete credit loss
phy_stats_clear_ts    06-23-2022 UTC Thu 14:06:23    Timestamp of phy_port stats clear
lgc_stats_clear_ts    06-23-2022 UTC Thu 14:06:23    Timestamp of lgc_port stats clear
  • Fabriclog 表示端口已反复闪联。
Switch 0; Mon Apr 10 09:34:46 2023 GMT (GMT+0:00)
09:34:56.224522 SCN Port Offline;rsn=0x2,g=0xc0        D0,P0  D0,P0  9    NA
09:34:56.224540 *Removing all nodes from port         D0,P0  D0,P0  9    NA
09:35:08.666250 SCN LR_PORT(0);g=0xc0             D0,P0  D0,P0  9    NA
09:35:08.671197 SCN Port Online; g=0xc0,isolated=0      D0,P0  D0,P1  9    NA
09:35:08.671407 Port Elp engaged               D0,P1  D0,P0  9    NA
13:00:36.370320 SCN Port Online; g=0xc4,isolated=0      D0,P0  D0,P1  9    NA
13:00:36.370531 Port Elp engaged               D0,P1  D0,P0  9    NA
13:00:36.370601 *Removing all nodes from port         D0,P0  D0,P0  9    NA
13:00:36.370803 SCN Port F_PORT                D0,P1  D0,P0  9    NA
13:11:22.396502 SCN LR_PORT(0);g=0xc4 LR_IN          D0,P0  D0,P0  9    NA
New to NetApp?
