跳转到主内容
由卷脱机导致的 CPU N-blade 极高延迟
342
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
适用于
ONTAP 9
问题
  • 来自 CPU N-blade 的极高延迟
  • EMS 中显示卷离线
[?]  Thu Aug 10 14:22:17 +0900 [node02: vv_config_worker11: wafl.vvol.offline:debug]: Volume 'xxxxxxxx' has been set temporarily offline
  • NFS 倒带和放弃的统计检查显示数百万个 VLDB 查找
Cluster::*> set -privilege diagnostics; statistics start -object rw_ctx -counter nfs_rewinds|nfs_giveups
Cluster::*> statistics show -node node-name
Object: rw_ctx
Instance: rw_ctx
Start-time: 4/22/2026 16:16:01
End-time: 4/22/2026 16:16:20
Elapsed-time: 19s
Scope: node-name
Counter                            Value
  nfs_giveups                            -
             Credentials                 0
               Export                 0
            VLDB Lookup                 15Mil. <----
New to NetApp?
