跳转到主内容
如出现电池(充电 FET/ 关闭)警告,请致电主页
42
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
适用于
  • FAS8040
  • ONTAP 9.7P8
  • 服务处理器( SP ) 3.10
问题
  • ONTAP 每小时会在 EMS 日志中报告 "battery" (电池)(充电 FET" 关闭)警告。
​​​​示例:
2/20/2021 08:28:44 node02 ALERT callhome.battery.warning: Call home for BATTERY (charge FET off) WARNING.
2/20/2021 08:28:14 node02 ERROR nvram.battery.chargeFET.off: The NVRAM battery charge FET is off. To prevent data loss, the system will shut down in 20 hours.
2/20/2021 07:28:44 node02 ALERT callhome.battery.warning: Call home for BATTERY (charge FET off) WARNING.
2/20/2021 07:28:14 node02 ERROR nvram.battery.chargeFET.off: The NVRAM battery charge FET is off. To prevent data loss, the system will shut down in 21 hours.
2/20/2021 06:28:44 node02 ALERT callhome.battery.warning: Call home for BATTERY (charge FET off) WARNING.
2/20/2021 06:28:14 node02 ERROR nvram.battery.chargeFET.off: The NVRAM battery charge FET is off. To prevent data loss, the system will shut down in 22 hours.
2/20/2021 05:28:44 node02 ALERT callhome.battery.warning: Call home for BATTERY (charge FET off) WARNING.
2/20/2021 05:28:14 node02 ERROR nvram.battery.chargeFET.off: The NVRAM battery charge FET is off. To prevent data loss, the system will shut down in 23 hours.
2/20/2021 04:28:44 node02 ALERT callhome.battery.warning: Call home for BATTERY (charge FET off) WARNING.
2/20/2021 04:28:14 node02 ERROR nvram.battery.chargeFET.off: The NVRAM battery charge FET is off. To prevent data loss, the system will shut down in 24 hours.
  • SP 日志 "system sensors" 显示 "CHARGE FET" OFF 。
示例:
Bat_Present    | 0x0     | discrete   | Present   | na     | na     | na     | na
Bat_Temp      | 20.000    | degrees C  | ok      | 0.000    | 5.000    | 53.000   | 58.000
Bat_Volt      | 8.000    | Volts    | ok      | 5.500    | 5.600    | 8.500    | 8.600
Bat_Curr      | 0.000    | Amps     | ok      | -4.000   | -0.040   | 1.200    | 1.520
Bat_Rem_Cap    | 3.072    | Amps * hour | ok      | na     | na     | na     | na
Bat_Full_Cap    | 3.072    | Amps * hour | ok      | na     | na     | na     | na
Bat_Charge_Curr  | 0.000    | Amps     | ok      | na     | na     | 2.200    | 2.300
Bat_Charge_Volt  | 0.000    | Volts    | ok      | na     | na     | 8.900    | 9.000
Bat_Design_Cap   | 5.500    | Amps * hour | ok      | na     | na     | na     | na
Bat_Initial_Fcc  | 4.200    | Amps * hour | ok      | na     | na     | na     | na
Bat_Dstg_Cycles  | 45.000    | cycles    | ok      | 2.000    | 5.000    | na     | na
Bat_Power_Fault  | 0x0     | discrete   | Deasserted | na     | na     | na     | na
Bat_Tca_Status   | 0x0     | discrete   | Asserted   | na     | na     | na     | na
Bat_Dcharge_FET  | 0x0     | discrete   | Deasserted | na     | na     | na     | na
Bat_Charge_FET  | 0x0     | discrete   | Asserted   | na     | na     | na     | na
Bat_Pack_Invalid | 0x0     | discrete   | Deasserted | na     | na     | na     | na
  • SP 日志 "events all" 还会显示 "CHARGE FET" OFF ,并且不会自动恢复。
示例:
 Fri Feb 19 19:22:06.182655 2021 [IPMI.notice]: c601 | 02 | EVT: 0300ffff | Bat_Tca_Status | Assertion Event, "State Deasserted" Fri Feb 19 19:28:13.791368 2021 [IPMI.notice]: c701 | 02 | EVT: 0301ffff | Bat_Tca_Status | Assertion Event, "State Asserted" Fri Feb 19 19:28:13.876524 2021 [IPMI.notice]: c801 | 02 | EVT: 0301ffff | Bat_Charge_FET | Assertion Event, "State Asserted" Fri Feb 19 19:28:14.081617 2021 [Agent.notice]: 727.659: 11 : Controller Attention LED asserted Fri Feb 19 19:28:14.081784 2021 [Agent.notice]: 727.659: 14 : Attention LED (at Midplane) asserted
New to NetApp?
