跳转到主内容
起動中にノードが NVRAM バッテリ電源障害を報告しました
99
Visibility:
Votes:
0
Category:
aff-series<a>AFF FAS</a><a /><a> NVRAM</a><a>NVRAMバッテリ</a><a>電源の障害です</a>
Specialty:
HW
Last Updated:
環境
  • ファブリック接続ストレージ( FAS )システム
  • すべての Flash FAS ( AFF )システム
問題
起動中に、ノードから次の警告メッセージが表示されます。
WARNING:  The battery is experiencing a critical failure:
           - Battery power fault
          Without a working battery, the system cannot retain data
          during a power outage, which can result in data loss.
          Power down the system and verify that the battery is
          properly installed.
          To ignore this failure and boot the system in a mode
          where data loss might occur, press 'c' followed by 'Enter'
CAUTION: Using this appliance without NVRAM
         battery backup coupled with a power
         failure condition CAN CAUSE DATA LOSS.
Are you sure you want to continue (y or n)?
または
HA Group Notification (BATTERY (fault)) CRITICAL
New to NetApp?
