跳转到主内容
由于 SAS 电缆故障,检测到"sas.cable.degraded"
142
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
适用于
  • ONTAP 9
  • SAS 存储架
问题
  • EMS 在降级模式下显示 sas 端口。
[sas.cable.degraded:error]: Cable attached to SAS port "0a" is functioning in a degraded mode.
  • 从  sysconfig -a  输出中检查时,某些 PHY 的速度会降低或禁用。示例:
slot 0: SAS Host Adapter 0a (PMC-Sierra PM8072 rev. C, SAS, <UP>)
Firmware rev: 03.08.09.00
Base WWN: 5:00a098:00f5e56:b0
Temperature: Not Available
Phy State: [0] Enabled, 6.0 Gb/s
      [1] Enabled, 12.0 Gb/s
      [2] Enabled, 3.0 Gb/s
      [3] Enabled, 12.0 Gb/s
或
slot 0: SAS Host Adapter 0b (PMC-Sierra PM8070 rev. C, SAS, <UP>)
        Base WWN:           5:00a098:003abb6:34
        Phy State:          [4] Disabled
                            [5] Enabled, 12.0 Gb/s
                            [6] Enabled, 12.0 Gb/s
                            [7] Enabled, 12.0 Gb/s
  • SAS 电缆重新拔插后,问题仍然存在。
  • "storage port show" 将 SAS 端口 0a 报告为 "online-degraded"
New to NetApp?
