跳转到主内容
NSM100 模块上的风扇陈旧错误状态发生原因错误故障 LED
141
Visibility:
Votes:
0
Category:
disk-shelves<a>NS224</a><a>NSM100</a><a>2008861783</a>
Specialty:
hw
Last Updated:
适用场景
  • NS224 架
  • NSM100 模块
问题描述
  • 重新启动、重新拔插或更换后、NSM100模块中的琥珀色故障LED。
  • EMS警告:
ses.status.fanWarning:notice]: NS224NSM100 (S/N serial) shelf 0 on channel 0x cooling fan warning for Cooling element 1: not operating. This element is on the unknown location.
  • 输出system node run -node <node> -command storage show fault -v表示一个或多个风扇传感器正常、但出现故障
  • 示例:
Fans:
Element Status         Status Bytes  Status Descriptions
11: OK                01,02,86,61  FAIL
12: OK                01,02,79,21
13: OK                01,02,6D,21
14: OK                01,02,7A,21
15: OK                01,02,74,61  FAIL
  • 但是、风扇运行正常、已通过确认 system node run -node * -command environment status
  • 示例:
Cooling Unit installed element list: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20; with error: none
Cooling Units by element:
[1] 6540 RPM
[2] 6390 RPM
[3] 6650 RPM
[18] 8090 RPM
[19] 8010 RPM
[20] 8000 RPM
  • AutoSupport 部分 STORAGE-SHELF.XML 可能还会在 affecter NSM模块下显示错误类型Acpp
New to NetApp?
