跳转到主内容
即使在更换 Flash Cache 后,故障 LED 也不会关闭
496
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • FAS2720/FAS2750
  • ONTAP 9
问题描述
  • 即使在更换有故障的 Flash Cache 后,故障 LED 仍然亮起。
  • "NVMe device failed"更换后仍有事件。
  • 无法通过执行以下命令清除错误事件。
 示例:
         ::> system controller service-event delete -node node-1 -event-id 1
::> system controller service-event show
 Node        ID  Event Location            Event Description
      node-01  1 Device in M.2 PCIe slot 1 in Controller A  NVMe device failed
  • 无法通过基板管理控制器(BMC)上的"system fru led set off"命令清除故障 LED。
示例:
BMC> priv set diag
BMC*> system fru led set 15 off
FRU LEDs status
<snip>
FRU LED ID 14 = BMC DIMM Slot 2 Attention LED
FRU LED ID 15 = BMC NVMEM 1 Attention LED
FRU LED ID 16 = BMC BOOT DISK Attention LED
<snip>
FRU LED ID 14 is off
FRU LED ID 15 is on
FRU LED ID 16 is off
  •  Flash Cache 状态在 sysconfig-a 中显示 Ok。
slot 1: Flash Cache NVMe
Serial Number: S2UWNX0HCXXXXX5
Part Number: 110-00466
Hardware Revision: A0
Firmware Version: NA00
Model Name: X3311A
Capacity: 1024 GB
State: ok
  • BMC 重新启动无法解决此问题。
New to NetApp?
