跳转到主内容
风扇正在高速运行、并且声音很大
323
Visibility:
Votes:
0
Category:
fas-systems<a>FAS2500系列</a><a>风扇</a><a>转</a><a>速</a><a>较高 </a>
Specialty:
hw
Last Updated:
状态信息
适用场景
  • AFF 系统
  • ASA 系统
  • FAS 系统
问题描述
  • 风扇旋转声音很大。
  • "environment status"表示即使服务器机房的温度正常、风扇仍以极高的速度运行。
示例:
Cooling Unit installed element list: 1, 2, 3, 4; with error: none
Cooling Units by element:
[1] 7850 RPM
[2] 7850 RPM
[3] 7870 RPM
[4] 7870 RPM
Temperature Sensor installed element list: 1, 2, 3, 4, 5, 6, 7, 8; with error: none
Shelf temperatures by element:
[1] 14 C (57 F) (ambient) Normal temperature range
[2] 33 C (91 F) Normal temperature range
[3] 36 C (96 F) Normal temperature range
[4] 57 C (134 F) Normal temperature range
[5] 37 C (98 F) Normal temperature range
[6] 47 C (116 F) Normal temperature range
[7] 59 C (138 F) Normal temperature range
[8] 56 C (132 F) Normal temperature range
New to NetApp?
