FAS8300/FAS8700/A400 主板更换 0 个磁盘,未找到根卷
适用于
- AFF A400、AFF C400
- ASA C400、ASA C400
- FAS8700, FAS8300
- ONTAP 9+
问题
- 在更换主板期间:
- 节点未引导到"
Waiting for giveback..."状态 - 磁盘自动重新分配失败,新主板进入引导循环:
- 节点未引导到"
Dec 30 10:44:24 [CLUSTER-02:cf.fm.noMBDisksOrIc:error]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.Dec 30 10:44:24 [CLUSTER-02:raid.assim.tree.noRootVol:error]: No usable root volume was found!WARNING: 0 disks found!Storage Adapters found:0 Fibre Channel Storage Adapters found!8 SAS Adapters found!0 Parallel SCSI Storage Adapters found!0 ATA Adapters found!Select option 4 from the boot menu to choose disks for the root volume and spare core space.Target Adapters found:4 Fibre Channel Target Adapters found!0 iSCSI Target Adapters found!WARNING: there do not appear to be any disks attached to the system.No root volume found.Rebooting... (press ctrl-c during boot to break reboot loop)- 健康节点在维护模式下显示以下错误:
> disk show -v
Local System ID: 999999000
DISK OWNER POOL SERIAL NUMBER HOME DR HOME CHKSUM
Nov 17 21:41:44 [AFF400-CLS-02:diskown.duplicateSoftEntries:notice]: Found duplicate filer_table entries with same name AFF400-CLS-02 but different system ids ( 888888000, 999999000 )
