跳转到主内容
FAS2720 启动失败,nvmem.battery.notPresent
124
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
适用于
  • FAS2720
  • FAS2750
问题
  • 节点启动时出现以下错误,并在 5 分钟后关闭。
WARNING:  The battery is experiencing a critical failure:
- Failed to detect the battery learning status
Without a working battery, the system cannot retain data
during a power outage, which can result in data loss.
Power down the system and verify that the battery is
properly installed.
To ignore this failure and boot the system in a mode
where data loss might occur, press 'c' followed by 'Enter'
[callhome.battery.failure:EMERGENCY]: Call home for BATTERY (not present) CRITICAL.
[nvmem.battery.notPresent:ALERT]: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
New to NetApp?
