跳转到主内容
环境原因关闭(电池组无效)
42
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
适用于
  • FAS8300
  • FAS9500、AFF-A900
问题
  • 紧急停机,原因为 Battery pack invalid
Jun 21 07:10:06 [krsl06nfc2-02:nvmem.battery.unread:EMERGENCY]: The NVMEM battery state cannot be determined because the 'Bat Pack Invalid' sensor is unreadable. To prevent data loss, the system will shut down in 5 minutes.
Jun 21 07:11:06 [krsl06nfc2-02:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Pack Invalid' unreadable) CRITICAL.
Jun 21 07:17:06 [krsl06nfc2-02:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery pack invalid)
Waiting for PIDS:  1084.
Terminated
Uptime: 102d17h42m31s
FM halt: Time 8876489612 ms, 22709097543240426 cycles
System powering down.
  • 电池组状态:
Bat_Dsg_FET_Flt  | 0x0        | discrete   | 0x0480| na        | na        | na        | na        | na        | na
Bat_Chg_FET_Flt  | 0x0        | discrete   | 0x0480| na        | na        | na        | na        | na        | na
Bat_Pack_Invalid | na         | discrete   | na    | na        | na        | na        | na        | na        | na
Bat_Lrn_Active   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
  • 控制器通电后问题仍然存在
New to NetApp?
  • 这篇文章对您有帮助吗?
