跳转到主内容
在 ONTAP 9.8 上,使用 DS4486 磁盘架的磁盘出现故障
13
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
适用场景
  • DS4486 磁盘架
  • ONTAP 9.8
问题描述
  • 升级到 9.8 后, DS4486 磁盘架中的磁盘将发生故障,在受影响的版本上执行接管和交还后,如果没有发生原因,也可能会出现故障:
Fri Jul 30 12:25:12 +0000 [node03: api_dpool_25: scsi.debug:debug]: shm_setup_for_failure disk 11d.07.15L1 (S/N 7PH8MKMG) error 40000000h
Fri Jul 30 12:25:12 +0000 [node03: api_dpool_26: scsi.debug:debug]: shm_setup_for_failure disk 11d.07.5L1 (S/N 7PH8LSNG) error 40000000h
Fri Jul 30 12:25:12 +0000 [node03: api_dpool_27: scsi.debug:debug]: shm_setup_for_failure disk 11d.08.22L1 (S/N 7PGSVKZG) error 40000000h
Fri Jul 30 12:46:08 +0000 [node03: api_dpool_10: scsi.debug:debug]: shm_setup_for_failure disk 11d.07.15L1(S/N 7PGRY6XG) error 40000000h
Fri Jul 30 12:46:08 +0000 [node03: api_dpool_11: scsi.debug:debug]: shm_setup_for_failure disk 11d.07.5L1 (S/N 7PGP6BTG) error 40000000h
Fri Jul 30 12:46:08 +0000 [node03: api_dpool_12: scsi.debug:debug]: shm_setup_for_failure disk 11d.08.22L1 (S/N 7PH8MLNG) error 40000000h
New to NetApp?
