跳转到主内容
IOM12E 和 PSU 缺少磁盘,风扇和温度错误
231
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
适用场景
  • AFF A220
  • FAS2750
  • FAS2720
  • IOM12E
问题描述
  • 一个或两个路径中缺少磁盘
    • 如果两个路径都缺少驱动器、则两个节点可能会重新启动、并且无法启动
  • 物理磁盘重新就位后、两个节点均关闭。
  • sysconfig -A 输出中缺少一个IOM12E模块:
Shelf 0: DS224-12 Firmware rev. A: ---- IOM12E B: 0220
  • 意外重新启动IOM12E。磁盘架日志消息示例:
Thu Jan 1 00:00:00 1970 ( 0+00:00:00.497); 02000027; U?; HAL; hal; 04; NDU Data Invalid.
Thu Jan 1 00:00:00 1970 ( 0+00:00:00.497); 02000093; U?; HAL; hal; 04; Module Reboot: Startup type 1-Cold boot
Sun Dec 31 03:04:33 +0900 [Node-01: storlog_admin: sla.shelf.mod.reboot.unexp:error]: Unexpected reboot event reported by module A in shelf: 0b.00.99.0, log: Thu Jan  1 00:00:00 1970 (    0+00:00:00.474); 02000093; U?; HAL; hal; 04; Module Reboot: Startup type 5-Crash reset
Sun Dec 31 03:04:33 +0900 [Node-01: storlog_admin: sla.shelf.message:debug]: params: {'type': 'SEVERITY', 'log': 'Thu Jan  1 00:00:00 1970 (    0+00:00:00.681); 0200013D; U?; HAL; hal; 02; Failure info:EXT NMI Handler'}
  • EMS环境错误示例:
Thu Apr 08 06:12:57 +0000 [node_name: dsa_worker2: ses.status.electronicsWarn:error]: DS224-12 (S/N SHFNC0123456789) shelf 0 on channel 0b environmental monitoring warning for SES electronics 1: not installed. This module is on the rear of the shelf at the top left.
Thu Apr 08 06:12:57 +0000 [node_name: dsa_worker2: ses.status.procCplxError:alert]: DS224-12 (S/N SHFNC0123456789) shelf 0 on channel 0b Processor Complex error for Processor Complex 1: PCM on partner not installed This module is on the unknown location.
Mon Apr 12 08:17:00 +0000 [node_name: dsa_worker4: ses.status.temperatureWarning:alert]: DS224-12 (S/N SHFNC0123456789) shelf 0 on channel 0a temperature warning for Temperature sensor 11: not operating. Current temperature: 49 C (120 F). This module is on the rear of the shelf at the top left, on shelf module A.
Mon Apr 12 08:17:00 +0000 [node_name: dsa_worker4: ses.status.temperatureWarning:alert]: DS224-12 (S/N SHFNC0123456789) shelf 0 on channel 0a temperature warning for Temperature sensor 12: not operating. Current temperature: 35 C (95 F). This module is on the rear of the shelf at the top left, on shelf module A.
Thu Apr 22 08:40:42 +0000 [node_name: dsa_worker3: ses.status.ModuleError:alert]: DS224-12 (S/N SHFNC0123456789) shelf 0 on channel 0a SAS expander error for SAS shelf electronics 1: critical status. This module is on the rear of the shelf at the top left, on shelf module A.
Thu Apr 22 10:17:28 +0000 [node_name: dsa_worker5: ses.status.psWarning:error]: DS224-12 (S/N SHFNC0123456789) shelf 0 on channel 0b power warning for Power supply 1: not installed. This module is on the rear of the shelf at the bottom left.
Thu Apr 22 10:17:28 +0000 [node_name: dsa_worker5: ses.status.psWarning:error]: DS224-12 (S/N SHFNC0123456789) shelf 0 on channel 0b power warning for Power supply 2: not installed. This module is on the rear of the shelf at the bottom right.
Thu Apr 22 10:27:50 +0000 [node_name: dsa_worker5: ses.status.temperatureWarning:alert]: DS224-12 (S/N SHFNC0123456789) shelf 0 on channel 0b temperature warning for Temperature sensor 14: not installed or failed. Current temperature: 28 C (82 F). This module is on the rear of the shelf at the top right, on shelf module B.
New to NetApp?
