跳转到主内容
控制器警示 LED 亮起,并由 SP 设置
415
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • FAS8040
  • FAS8020
  • 服务处理器 (SP)
问题
  • 控制器警示 LED 亮起。
  • 可在以下命令输出中找到 SP 设置的。
ONTAP 集群模式
示例:
cluster::*> system controller fru led show
Node                  FRU Type    Bay Slot State   Lit By
cluster-01
                      controller  A   1    off     -
                      pci         -   1    off     -
                      pci         -   2    off     -
                      pci         -   3    off     -
                      pci         -   4    off     -
                      batt-nv     -   1    off     -
                      boot        -   1    off     -
                      dimm-nv     -   1    off     -
                      dimm        -   1    off     -
                      dimm        -   2    off     -
                      dimm        -   3    off     -
                      dimm        -   4    off     -
cluster-02
                     controller  B   1    on      SP
                      pci         -   1    off     -
                      pci         -   2    off     -
                      pci         -   3    off     -
                      pci         -   4    off     -
                      batt-nv     -   1    off     -
                      boot        -   1    off     -
                      dimm-nv     -   1    off     -
                      dimm        -   1    off     -
                      dimm        -   2    off     -
                      dimm        -   3    off     -
                      dimm        -   4    off     -
Data ONTAP 8.2 7-模式
示例:
node*> fru_led status
Controller slot B: On (lit by SP)
DIMM slot 1:     Off
DIMM slot 2:     Off
DIMM slot 3:     Off
DIMM-NV slot 1:   Off
PCI slot 1:     Off
PCI slot 2:     Off
NV battery 1:    Off
Boot device 1:    Off
New to NetApp?
  • 这篇文章对您有帮助吗?
