跳转到主内容
控制器注意力指示灯亮起,带有扩展器设置
473
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • FAS2720
  • FAS2750
问题
  • 控制器注意 LED 亮起。
  • 由扩展器设置的内容可以在以下命令输出中找到。
示例:
FRU LEDs status
FRU LED ID 1  = BMC Locate LED
FRU LED ID 2  = BMC System LED
FRU LED ID 3  = BMC Controller Attention LED
FRU LED ID 4  = BMC Controller Active LED
FRU LED ID 5  = BMC SAS Port A Attention LED
FRU LED ID 6  = BMC SAS Port B Attention LED
FRU LED ID 7  = BMC CNA Port 1 Attention LED
FRU LED ID 8  = BMC CNA Port 2 Attention LED
FRU LED ID 9  = BMC CNA Port 3 Attention LED
FRU LED ID 10 = BMC CNA Port 4 Attention LED
FRU LED ID 11 = BMC 10G Port 1 Attention LED
FRU LED ID 12 = BMC 10G Port 2 Attention LED
FRU LED ID 13 = BMC DIMM Slot 1 Attention LED
FRU LED ID 14 = BMC DIMM Slot 2 Attention LED
FRU LED ID 15 = BMC NVMEM 1 Attention LED
FRU LED ID 16 = BMC BOOT DISK Attention LED
FRU LED ID 17 = BMC NV BATTERY Attention LED
FRU LED ID 18 = BMC Coin Cell Attention LED
FRU LED ID 1 is off
FRU LED ID 2 is on. Set by Expander
FRU LED ID 3 is off
FRU LED ID 4 is off
FRU LED ID 5 is off
FRU LED ID 6 is off
FRU LED ID 7 is off
FRU LED ID 8 is off
FRU LED ID 9 is off
FRU LED ID 10 is off
FRU LED ID 11 is off
FRU LED ID 12 is off
FRU LED ID 13 is off
FRU LED ID 14 is off
FRU LED ID 15 is off
FRU LED ID 16 is off
FRU LED ID 17 is off
FRU LED ID 18 is off
  • 无法通过重新启动 BMC 来解决此问题。
  • 无法通过运行 system fru led set <ID> off命令解决此问题。
BMC>priv set diag
BMC*>system fru led set <ID> off
New to NetApp?
