跳转到主内容
集群端口 e0a 和 e0b 关闭导致 CLAM 恐慌 - 电源循环无法解决
63
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • AFF A300、FAS8200
  • AFF A200、FAS2650、FAS2620
  • AFF A220、AFF C190、FAS2750、FAS2720
  • 两个节点集群
  • 已启用连接、活力和可用性监视器 (CLAM)
    • ONTAP 9.8 或更高版本
    • 使用 SAN 实体配置的集群
问题
  • 集群端口 e0a 和 e0b 关闭,导致一个节点被接管
Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0b: snmp.link.down:info]: Interface 2 is down.
Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0b: netif.linkDown:info]: Ethernet e0b: Link down, check cable.
Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0a: snmp.link.down:info]: Interface 1 is down.
Tue Oct 03 11:08:31 CEST [node1: ixgbe/e0a: netif.linkDown:info]: Ethernet e0a: Link down, check cable.
Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0b: snmp.link.down:info]: Interface 2 is down.
Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0b: netif.linkDown:info]: Ethernet e0b: Link down, check cable.
Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0a: snmp.link.down:info]: Interface 1 is down.
Tue Oct 03 11:08:32 CEST [node2: ixgbe/e0a: netif.linkDown:info]: Ethernet e0a: Link down, check cable.
  • 其中一个节点发生"超出仲裁范围"的恐慌。
PANIC  : Received PANIC packet from partner, receiving message is (Coredump and takeover initiated because Connectivity, Liveliness and Availability Monitor (CLAM) has determined this node is out of quorum.
New to NetApp?
