跳转到主内容
机箱温度过高:入口 ODP 温度 X 警告高
75
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
适用于
AFF A90
问题描述
  • 系统报告多个与温度相关的警报,包括机箱温度过高和入口温度警告。示例
... [node_name: monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high..
... [node_name: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Inlet ODP Temp1 is warning high (42 C).
... [node_name: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Inlet ODP Temp2 is warning high (42 C).
... [node_name: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
  • 警报可能会在几分钟后清除。示例
... [node_name: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
Sys Inlet Temp      normal       37 C
Inlet ODP Temp1     warnhigh      42 C
Inlet ODP Temp2      normal       41 C
New to NetApp?
