AFF A400、C400、FAS8300、FAS8700のシャーシファンFRUに障害が発生しました
環境
- AFF A400、C400
- FAS8300、FAS8700
- ファンFRU
問題
- EMSで次のエラーが報告される
Dec 06 17:27:00 [node02:monitor.globalStatus.critical:EMERGENCY]: There are no enough spare disks. Assign unowned disks. One fan has failed: SysFan4 F2.
Dec 06 17:33:00 [node02:monitor.globalStatus.critical:EMERGENCY]: There are no enough spare disks. One fan has failed: SysFan4 F2.
Wed Dec 07 13:31:38 +0900 [node02: notifyd: asup.post.drop:error]: AutoSupport message (HA Group Notification from iscsi-vc054-swn-02 (CHASSIS FAN FRU FAILED: Fan4_2) ERROR) was not posted to NetApp. The system will drop the message.
- 一方または両方のファンのセンサーステータスはです
"BAD"
SysFan4 F1 discrete normal normal GOOD
SysFan4 F2 discrete fault normal BAD
