跳转到主内容
机箱风扇 FRU 出现故障:多个风扇出现故障
97
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • FAS8200
  • ONTAP 9
问题描述
  • EMS 报告有关风扇的多个错误
Mon Feb 20 09:42:57 +0900 [node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan1 F2
Mon Feb 20 09:42:57 +0900 [node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan2 F1
Mon Feb 20 09:44:02 +0900 [node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan2 F2
Mon Feb 20 09:44:27 +0900 [node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan3 F1
Mon Feb 20 09:44:42 +0900 [node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan3 F2
Mon Feb 20 10:42:40 +0900 [node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan1 F1
Mon Feb 20 10:42:59 +0900 [node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan1 F2
Mon Feb 20 10:43:00 +0900 [node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan2 F1
Mon Feb 20 10:44:06 +0900 [node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan2 F2
Mon Feb 20 10:44:30 +0900 [node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan3 F1
Mon Feb 20 10:44:43 +0900 [node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan3 F2
Mon Feb 20 09:00:00 +0900 [node1: statd: monitor.fan.failed:alert]: Multiple fans has failed: Sysfan1 F1, Sysfan1 F2, Sysfan2 F1, Sysfan2 F2, Sysfan3 F1, Sysfan3 F2.
Mon Feb 20 10:00:00 +0900 [node1: statd: monitor.fan.failed:alert]: Multiple fans has failed: Sysfan1 F1, Sysfan1 F2, Sysfan2 F1, Sysfan2 F2, Sysfan3 F1, Sysfan3 F2.
  • SP 传感器的风扇状态为坏
Sysfan3 F2                  BAD
Sysfan3 F1                  BAD
Sysfan2 F2                  BAD
Sysfan2 F1                  BAD
Sysfan1 F2                  BAD
Sysfan1 F1                  BAD
Chassis Thermal Zone           OVER_TEMP
Thermal Shutdown               UP
CPU0 Avg Critical               NO
Temp Average Low               NO
Temp Average High               NO
CPU0 Temp Avg       normal       -65 C     --      --      -11 C     -1 C
InFlow Temp Avg      normal       25 C      0 C      5 C     50 C     55 C
OutFlow Temp Avg      normal       38 C      0 C      5 C     65 C     75 C
PCI Temp Avg        normal       34 C      0 C      5 C     60 C     70 C
Bat Temp Avg        normal       31 C      0 C      5 C     60 C     70 C
Amb2 Temp Avg       invalid       -- C      0 C      5 C     47 C     52 C
Amb1 Temp  Avg       invalid       -- C      0 C      5 C     47 C     52 C
PSU2 FRU Fan                 OK
PSU2 FRU Power                ON
PSU1 FRU Fan                 OK
PSU1 FRU Power                ON
Fan3 INFO                 FAILED
Fan2 INFO                 FAILED
Fan1 INFO                 FAILED
PSU1 INFO                 FRU_AVAIL
PSU1 INFO                 FRU_AVAIL
Fan1                   MULTIFAULT
Fan2                   MULTIFAULT
Fan3                   MULTIFAULT
PSU1                    GOOD
New to NetApp?
