跳转到主内容
机箱风扇 FRU 故障:由于集群间 LIF 流量过大,多个风扇发生故障
32
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
适用场景
  • ONTAP 9
  • FAS 26xx系列
  • FAS 27xx系列
问题描述
  • HA 对中的一个节点报告读取温度传感器的问题,该问题已自动得到纠正:
[node1: env_mgr: monitor.fan.warning:notice]: multiple fans have failed. Replace it to avoid overheating
[node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Module B Expander Temp) is not readable.
[node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Module A Expander Temp) is not readable.
[node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 4 Temp) is not readable.
[node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 3 Temp) is not readable.
[node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 2 Temp) is not readable.
[node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 1 Temp) is not readable.
[node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Ambient Temp) is not readable.
[node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Multiple fans have failed
[node1: env_mgr: monitor.fan.ok:notice]: All fans are OK.
[node1: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
[node1: monitor: monitor.globalStatus.ok:notice]: The system's global status is normal.
  • 受影响节点上的某些温度传感器不可用,而伙伴节点则将其报告为正常。
cluster1::> system node run -node * -command environment status
2 entries were acted on.
Node: node1
      Shelf temperatures by element:
       [10] 28 C (82 F)  Normal temperature range
       [11] Unavailable
       [12] Unavailable
       [13] 29 C (84 F)  Normal temperature range
Node: node2
      [10] 33 C (91 F)  Normal temperature range
     [11] 48 C (118 F)  Normal temperature range
      [12] 26 C (78 F)  Normal temperature range
      [13] 34 C (93 F)  Normal temperature range
  • 当问题仍然存在但仅来自一个节点时,FRU 状态会显示为降级:
cluster1::> system controller fru show
Node         FRU Name            Subsystem      Status
node1        PSU1 FRU            Environment     degraded
node1         PSU2 FRU            Environment     degraded
node2         PSU1 FRU            Environment     ok
node2         PSU2 FRU            Environment     ok
  • 受影响节点的 BMC 频繁重启并在 SP 事件日志中报告以下内容:
Record 1250: Sat Jan 28 10:04:27.990616 2023 [BMC.critical]: Rebooting SP due to loss of ACP comms
Record 1251: Sun Jan 01 00:00:23.962645 2017 [IPMI.notice]: 00fd | c0 | OEM: ffff70005100 | ManufId: 150300 | BMC Reset Internally
  • 问题发生期间对端口 e0M 进行的数据包跟踪分析显示来自集群间逻辑接口 (IC LIF) 的传入流量很高。
New to NetApp?
