跳转到主内容
电池电量低,SP HBT 丢失
227
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • ONTAP 9
  • 服务处理器 (SP)
问题描述
  • EMS 报告 BATTERY_LOW。
[node: statd: monitor.nvramLowBattery:critical]: NVRAM battery is dangerously low.
[node: statd: monitor.nvramLowBattery.notice:info]: If the NVRAM battery is dangerously low, the system shuts down automatically every 24 hours to encourage you to replace it. If you reboot the system it will run for another 24 hours before shutting down.
[node: statd: callhome.battery.low:error]: Call home for BATTERY_LOW
[node: statd: monitor.shutdown.nvramLowBattery.pending:warning]: NVRAM battery is dangerously low. Halting system in 24 hours. Replace the battery immediately!
  • SP-LATEST-IPMI 表示电池电量正常。
Bat_1.5V         | 1.494      | Volts      | ok         | 1.280     | 1.348     | 1.649     | 1.727
Bat_3.0V         | 3.146      | Volts      | ok         | 2.545     | 2.703     | 3.504     | 3.575
Bat_8.0V         | 7.800      | Volts      | ok         | 6.000     | 6.600     | 8.600     | 8.700
Bat_Curr         | 0.000      | Amps       | ok         | na        | na        | 0.800     | 0.900
Bat_Capacity     | 1.792      | Amps * hour | ok         | na        | na        | na        | na
Bat_Run_Time     | 114.000    | hour       | ok         | 76.000    | 78.000    | na        | na
Bat_Temp         | 25.000     | degrees C  | ok         | 0.000     | 10.000    | 55.000    | 64.000
Charger_Curr     | 0.000      | Amps       | ok         | na        | na        | 2.200     | 2.300
Charger_Cycles   | 35.000     | cycles     | ok         | na        | na        | 250.000   | 251.000
Charger_Volt     | 8.200      | Volts      | ok         | na        | na        | 8.600     | 8.700
  • EMS 报告 SP HBT MISSED 之后 BATTERY_LOW。
[node: spsm_listener: sp.heartbeat.stopped:warning]: Have not received a IPMI heartbeat from the Service Processor (SP) in last 20 seconds.
[node: spsm_listener: callhome.sp.hbt.missed:notice]: Call home for SP HBT MISSED
New to NetApp?
  • 这篇文章对您有帮助吗?
