跳转到主内容
磁盘上的琥珀色 LED
427
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • DS224C
  • FAS2650
  • FAS2750
问题
  • 磁盘指示灯为琥珀色,但 ONTAP 未报告任何错误
  • storage show fault 命令未返回任何故障
::> system node run -node Node-01 -command storage show fault
No faults found in storage subsystem
  • 同一命令的详细输出显示磁盘已被两个 IOM 绕过
system node run -node Node-01 -command storage show fault -v
Node: Node-01
Enclosure Status: non-critical
Channel: 0a
Shelf: 0
Shelf Type: DS224-12
Product Serial Number: SHFHUXXXXXXXXXX
Module Type: IOM12E
Disk Elements:
Element Status                  Status Bytes  Status Descriptions
0 [Bay  0]: OK                    01,00,00,00
1 [Bay  1]: OK                    01,01,00,00
2 [Bay  2]: OK                    01,02,00,00
3 [Bay  3]: NONCRITICAL           03,0A,20,08   ENCLOSURE BYPASSED A, BYPASSED A
New to NetApp?
  • 这篇文章对您有帮助吗?
