运行SANtricity OS 11.70.4x时、E系列控制器更换失败
- 696
- Visibility:
- Public
- Votes:
- 0
- Category:
- e-series-systems
- Specialty:
- esg<a>ACS</a><a>2009年443093</a>
- Last Updated:
适用场景
- NetApp E 系列
- NetApp StorageGRID设备
- 更换控制器(HeadSwap)机箱:
- 单工E系列(即SG57xx)更换、其中原始控制器 运行的是11.70.4x或更高版本、而 更换控制器运行的是11.70.4x之前的版本
- 在更换双工E系列双控制器 的同时、原始控制器 运行11.70.4x、而 更换控制器运行11.70.4x之前的版本
问题描述
- 更换用的控制器无法启动和锁定,
OE L5控制器背面的7段显示屏上显示(Auto Code Syncrization Failure [自动编码同步故障])。 - 控制器控制台输出(
dom0-misc-logs-%.txt或中的日志文件/var/log/eos)将显示以下内容:
02/02/23-17:55:54 (tRAID): NOTE: ACS: download manager is idle
02/02/23-17:55:54 (tRAID): NOTE: ActiveInfo:ver='08.72.00.00' date='2021-12-08' time='19:35:23'
02/02/23-17:55:54 (tRAID): NOTE: ACS: Acs Needed on Alt: No, StateCode: 5, ReasonCode = 15
02/02/23-17:55:54 (tRAID): WARN: ACS findImages - 4 extents found for Dom0 Image
02/02/23-17:55:54 (tRAID): WARN: void acs::Image::determineDiskBlockSize(acs::Image::ExtentList&): Could not find a drive to set the block size
02/02/23-17:55:54 (tRAID): WARN: UINT32 acs::Image::getDiskBlockSize() const: DISK_BLOCK_SIZE has not been set yet!
02/02/23-17:55:54 (tRAID): NOTE: ACS findImages Dom0 error reading header
02/02/23-17:55:54 (tRAID): WARN: ACS no valid Dom0Image found
02/02/23-17:55:54 (tRAID): NOTE: ACS Dom0 getCompleteImages - 0 images to evaluate
02/02/23-17:55:54 (tRAID): NOTE: ACS no Dom0 images found - aborting request
02/02/23-17:55:54 (tRAID): NOTE: ACS from drive image complete - status: -1
02/02/23-17:55:54 (tRAID): ERROR: ******************************************************
02/02/23-17:55:54 (tRAID): ERROR: * ACS Failed. Code sync was required, but it failed. *
02/02/23-17:55:54 (tRAID): ERROR: * Start of Day will be suspended on this controller *
