跳转到主内容
检测到直连主机丢失主机端连接冗余
343
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
适用场景
  • NetApp E 系列
  • SANtricity OS 11.30或更高版本
  • 直连主机
问题描述
  • 报告的主要事件日志Loss of host-side connection redundancy detected :
示例:
Date/Time: 1/2/21, 1:02:03 AM
Sequence number: 1234
Event type: 9102
Event category: Error
Priority: Critical
Event needs attention: true
Event send alert: true
Event visibility: true
Description: Loss of host-side connection redundancy detected
Event specific codes: 0/0/0
Component type: Host
Component location: Host HOST1-HBA2
Logged by: Controller in bay A
  • 正在报告Recovery Guru Entry Host Redundancy Lost :
示例:
Failure Entry 1: ALB_HOST_REDUNDANCY_LOST-Recovery Failure Type Code: 475
Storage array: Unnamed
Affected host: HOST1-HBA2
Affected controller: Controller in bay B
  • 该主机具有两个HBA、它们配置为E系列中的两个独立主机。每个HBA都直接连接到其中一个控制器(A或B)。可以使用 storage-array-profile log 文件的HOST-TO-VOLUME ASSIGNMENTS 部分或SANtricity系统管理器中的Hosts部分来验证这一点。
New to NetApp?
