跳转到主内容
在 EF300 上添加驱动器架后第二个 SAS 连接断开
19
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
适用于
  • NetApp E 系列
  • EF300
  • DE224C 驱动器架
问题
  • 连接新驱动器架后,两个控制器上的第二个 SAS 连接均已关闭。
      Drive interface:        SAS
         Channel:             3
         Part type:           LSISAS3616    revision 402,653,184
            Status:           Up
         Maximum data rate:   12 Gbps
         Current data rate:   12 Gbps
         Channel:             4
            Status:           Down
         Current data rate:   Not available
  • IOMB 显示“Optimal”状态,但不显示固件或速度详细信息。
             IOM status:                      Optimal
             Firmware Version:                0202
             Configuration settings version:  Not Applicable
             Card communication:              OK
             Trunking supported:              No
             Product ID:                      DE224C
             Board ID:                        Ermine
             IOM status:                      Optimal
             Firmware Version:                Not Available
             Maximum data rate:               Not Available
             Current data rate:               Not Available
             Product ID:                      Not Available
             Board ID:                        Not Available
  • 观察到的 Recovery Guru 错误:
Failure Entry 1: LOSS_OF_EXTERNAL_REDUNDANCY-Recovery Failure Type Code: 449
Storage array: Fujitsu_Storage
Controller in bay A
Channel ID: 4
Controller in bay B
Channel ID: 4
Failure Entry 2: LOST_REDUNDANCY_TRAY-Recovery Failure Type Code: 33
Shelf: Drive shelf 11
Working channel: 3
或
Failure Entry 1: DRIVE_TRAY_LOSS_OF_EXTERNAL_REDUNDANCY-Recovery Failure Type Code: 449
Controller in bay A
Channel ID: 4
Controller in bay B
Channel ID: 4
Failure Entry 2: NO_REDUNDANCY_TRAY-Recovery Failure Type Code: 33
Working channel: 3
  • 新驱动器架路径冗余丢失;只有一个路径处于活动状态。
         Shelf path redundancy:  Lost
         Current drive types:    SAS
         Product ID:             DE224C
         Part number:            CA08733-3142
New to NetApp?
