跳转到主内容
E4000 IOM 失败,存在最高温度超出警报
116
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
适用于
  • NetApp E4000
  • StorageGRID 设备 SG6160
问题
SANtricity System Manager 报告超过最大温度阈值,并且针对一个 E4000 存储控制器的 IOM 故障
超过最大温度阈值 Recovery guru 条目示例:
Failure Entry 2: MAX_TEMP_EXCEEDED-Recovery Failure Type Code: 8
Storage array: StorageGRID-cmb1sgcn01
Component reporting problem: Thermal sensor B1
Status: UNKNOWN
Component requiring service: Temperature sensor
Shelf: Controller/Drive shelf 0
New to NetApp?
