跳转到主内容
E-Series 电源故障 - 无电源输入
622
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
适用于
  • NetApp E-Series
  • StorageGRID 设备
问题
  • Recovery Guru 报告:
Failure Entry 1: SUPPORT_CRU_NOINPUT-Recovery Failure Type Code: 97
Storage array: E2812
Component reporting problem: Power supply canister (Right)
Status: No power input
Component requiring service: Power supply canister (Right)
Service action (removal) allowed: Yes
Service action LED on component: No
Subcomponent affected: Power supply (99)
  • Storage Array Profile 显示电源风扇罐和电源没有电源输入:
Power-Fan Canisters Detected:  2
         Power-fan canister (Left) status:  Optimal
         Part number:                       114-00148+E0
         Serial number:                     111111111111111
         Date of manufacture:               Not Available
         Power-fan canister (Right) status:  No AC power input
         Serial number:                      222222222222222
  • 对于电源罐也包括风扇的系统(即 SG5712、E2812),则 Recovery Guru 中也会报告以下故障:
  • 如果启用 AutoSupport,则向最终用户发送电子邮件。作为回报,如果必须开启支持个案,用户有 24 小时的时间回复。电子邮件通知将用于:  E-Series Notification (Power supply failed) CRITICAL
    • 从 SANtricity 操作系统 11.70.3 开始,如果电源故障原因是电源输入丢失,则不会发送 AutoSupport 消息。但是,如果在 SANtricity System Manager 中配置了电子邮件通知(为警报配置邮件服务器和收件人),则会向最终用户发送电子邮件。
  • StorageGRID System Manager 报告以下警报:
    • Appliance overall power supply degraded
    • Appliance storage shelves degraded
    • Appliance storage controller hardware issue
New to NetApp?
