由于内部以太网通信链路丢失、E系列E2800控制器管理出现故障
适用场景
- NetApp E 系列
- NetApp StorageGRID
- 平台:
- 各种驱动器机箱(DE212c、DE224c和DE460c)中的E系列独立E2800控制器
- StorageGRID SG6060设备
问题描述
- SANtricity系统管理器中的多个功能出现故障或缺少某些数据。
- SANtricity 固件升级(控制器和磁盘):
Inter-controller interfaces link failure. One or more inter-controller interfaces have link down. You cannot upgrade the storage array until the problem is resolved. Use the Recovery Guru to fix the problem.
- 卷配置更改(创建、扩展、删除等)
- 在 "设置">"证书"下、配对控制器的管理证书状态未知
- 无法查看性能信息板统计信息
- 根据 (1) 管理请求类型和 (2)管理 方法(SANtricity系统管理器"SAM"、统一管理器、命令行界面)、可能会显示不同的错误消息
- 在SANtricity系统管理器(SAM)中:
The controller in slot 1, with an id of '070000000000000000000001', could not be contacted. (Web server 422) - 在SANtricity系统管理器(SAM)中:
The controller in slot 2, with an id of '070000000000000000000002', could not be contacted. (Web server 422) - 在SANtricity企业管理窗口中:
There was an error during the download operation. View the Online Help for information about diganosing and resolving errors. Click on the View Log button to look for the error "Unknown"在SAM的 "Settings"(设置)->"Certificates"(证书)下、为配对控制器创建管理证书- 在SANtricity固件升级期间:
Cannot Perform Upgrade Operation - An unknown issue occurred while performing the upgrade operation. Please try again.
- AutoSupport或手动生成的支持数据将丢失备用控制器中的数据。它将包含从中捕获数据的控制器的完整信息。部分预期缺失数据为:
dom0-daily-diagnostics-%.7zdom0-complete-journal-%.7zweb-server-trace-log-%.7z- 空
perf-stats-xx-summary-%.csv、但出现错误:devmgr.versioned.sam.jal.ManagementOperationFailedException: Error 10007 - Could not communicate with the controller in bay A to complete this request.
- 在运行11.70.4或更高版本操作系统的系统上、主要事件日志中会记录以下事件:
Link issues have been encountered on an alternate controller Ethernet channel
