跳转到主内容
E系列驱动器更换后无响应
356
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
适用于
  • NetApp E-Series
  • 所有固件版本
  • 磁盘驱动器已更换
问题
  • 在 STORAGE-ARRAY-PROFILE中,驱动器在 更换后显示无响应
      SHELF, DRAWER, BAY  STATUS        CAPACITY   MEDIA TYPE       INTERFACE TYPE  CURRENT DATA RATE  PRODUCT ID       FIRMWARE VERSION  CAPABILITIES
      99,    4,      6    Optimal       10.692 TB  Hard Disk Drive  SAS             12 Gbps            HUH721212AL5204  NE00              DA
      99,    4,      7    Unresponsive
      99,    4,      8    Optimal       10.692 TB  Hard Disk Drive  SAS             12 Gbps            HUH721212AL5204  NE00              DA
  • Recovery Guru  消息还显示 无响应磁盘
Failure Entry 4: FAILED_DRIVE-Recovery Failure Type Code: 23
Storage array: ArrayName
Component reporting problem: Drive in bay 0
Status: Unresponsive
New to NetApp?
