跳转到主内容
IOM (ESM)定期报告异常事件、但未检测到E-Series上的任何明显问题
13
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
适用场景
  • E 系列
  • 磁盘架上的I/O模块(IOM)或环境服务模块(ESM)
问题描述
  • 在重大事件日志中、 IOM (ESM) has reported an exception event has occurred 定期显示消息
Date/Time: xxx-xx-xx-xx
Sequence number: 3271
Event type: 2866
Event category: Failure
Priority: Warning
Event needs attention: true
Event send alert: true
Event visibility: true
Description: An IOM (ESM) has reported an exception event
Event specific codes: 0/0/0
Component type: Tray Component (ESM)
Component location: Tray 1, Slot B
Logged by: Controller in slot A
  • 检查Recovery Guru是否没有警报,此外,IOM (ESM) 处于最佳 状态:
     ESM card status:         Optimal
     Firmware Version:         0120
     Configuration settings version:  Not Applicable
     Maximum data rate:         12 Gbps
     Current data rate:         12 Gbps
     Card communication:        OK
     Trunking supported:        No
     Product ID:            DE224C
     Part number:            111-04850+A3
     Serial number:           032241xxxxxx
     Date of manufacture:        Not Available
     Product ID:            DE224C
  • 在ASUP ->上未找到任何结果 TRAY-COMPONENT-STATE-CAPTURE.7Z log
New to NetApp?
