跳转到主内容
由于FC链路故障、导致"主机端连接冗余丢失"
118
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
适用场景
  • NetApp E 系列
  • 光纤通道连接
问题描述
  • 系统生成警报报告、并在控制器 重新启动后持久保留:
Loss of host-side connection redundancy detected
  • RECOVERY-GURU-PROCEDURES.HTML 中的错误:
ALB_HOST_REDUNDANCY_LOST-Recovery Failure Type Code: 475
  • Major Event Logs PARSER 中的错误:
Loss of host-side connection redundancy detected - Host hostname <--CRITICAL
Volume not on preferred path due to AVT/RDAC failover - Shelf XX, Bay X <--CRITICAL
  • 一个控制器的端口0a和0b上的FC链路已关闭:
Host interface:                  Fibre
         Host Interface Card(HIC):     Baseboard
         Channel:                      1
         Port:                        0a, 0a
         Current ID:                   Not applicable/0xFFFFFFFF
         Preferred ID:                 0/0xEF
         NL-Port ID:                   0xFFFFFF
         Maximum data rate:            16 Gbps
         Current data rate:            Not available
         Data rate control:            Auto
         Link status:                 Down
         Channel:                      2
         Port:                        0b, 0b
         Preferred ID:                 1/0xE8
         Link status:                 Down
  • 在出现"主机端连接冗余丢失"错误之前、端口0A 已启动
New to NetApp?
